543 visninger | Oprettet:
Pioneer GM-D9601 forstærker??? {{forumTopicSubject}}
Ville sådan en Pioneer GM-D9601 kunne trække 2 stk Alpine SWR 1223D Type R 12" ????
Pioneer info:
Maximum Output Power 1 x 1000W (4O)
1 x 1600W (2O)
1 x 2400W (1O) .
Continuous power output (RMS) 1 x 500W RMS(4O)
1 x 800W RMS(2O)
1 x 1200W RMS(1O) .
Frequency response 10 - 24,000 Hz .
Distortion 10W, 100Hz ref. < 0.5 % .
S/N ratio > 100 dB .
Bass Boost Fjernbetjening
Frekvens 50 Hz, niveau 0-18 dB .
LPF 40 - 240 Hz (-12 dB/oct) .
RCA terminals Ja .
Speaker Terminals Block-type .
Speaker line input sensor Aktiveringssensor .
Input level control RCA (0.2V - 6.5V)
SP (0.8V - 16V) .
Max. current consumption (A/4O) 39 A .
Chassis size (W x H x D) 315 x 60 x 200 mm .
Unit weight 3.3 kg
Alpine subberne:
RMS Power Handling: 600 Watts
Peak Power Handling: 1800 Watts
Dimensions
Mounting Depth: 162 mm
Mounting Diameter: 275 mm
Displacement: 0.100 ft3
Added Volume: 0.090 ft3
General
Nominal Impedance: 2 Ohm + 2 Ohm
Frequency Response: 24-200 Hz
Kommentarer på:  Pioneer GM-D9601 forstærker???
