Lys til forstærker {{forumTopicSubject}}
Hej BG folk
Er der nogle af jer der har eller ved hvor man kan købe neonrør der passer lige ind i hullerne på denne JBL forstærker??
Hej BG folk
jan 2009
Følger: 36 Følgere: 29 Biler: 2 Emner: 9 Svar: 47
dec 2008
Følger: 34 Følgere: 31 Biler: 1 Emner: 2 Svar: 6
apr 2013
dec 2008
apr 2013
dec 2008
apr 2013
dec 2008
apr 2013
apr 2013
dec 2008
apr 2013
apr 2013
electronicshelponline.blogspot.dk/2013/05/jbl-gto3011-gto6011-gto12011.html
INSTALLING NEON TUBES
Using a Phillips screwdriver, remove all screws on the amplifier’s output/power end panel and set them aside.
Using a 3 / 32-inch Allen wrench, remove only the screws on the amplifier’s (top) clear cover and set them aside.
Remove the end panel and slide the cover off. Set both parts aside.
Locate the enclosed hardware bag and remove the four clips. Each clip has a square end and a larger round end. Using a round end, press two clips onto each neon tube (e.g., Street Glow AN9 or equivalent).
For each tube, align both clips so the square ends slide onto an exposed extrusion edge. Do not cover any screw holes. When installed correctly, each neon tube will sit under an extrusion and not be visible when viewed from directly above.
Route each neon tube’s power cable through its respective NEON hole on the end panel.
Slide the cover back into place and re-install its screws. Then, replace the end panel and reinstall its screws.
Finish the installation of the neon tubes as instructed in their owner’s manual.
http://www.ebay.com/itm/Streetglow-AN9-PURPLE-MINI-NEON-ACCENT-KIT-/181403470303
Lys til forstærker
