1.033 visninger | Oprettet:
alpine sub,,, priser {{forumTopicSubject}}
hvordan kan det være at de her koster det samme på hifipriser.dk
Alpine SWR-1022D Subwoofer 10" 500W RMS 2 Ohm
[Subwoofer Power Features]
• Peak Power 1500W
• RMS Power 500W
• Frequency Response: 28Hz - 500Hz
• High Excursion 1" Santoprene Edge
• Kevlar Reinforced Pulp Cone
• Dual Progressive Nomex Spiders with Edge Control
• Integrated Tinsel Lead Spider Design
• Custom Cast Aluminium Frame with Integrated Heat Transfer Plate
• Extended Length Dual-Flared Vented Pole Design
• High-Strength Brass Voice Coil Bobbin
• Heavy-Duty 10cm2 Push Terminals
• Computer Optimized Magnetic Circuit
• Designed and Engineered in the USA
den anden
Alpine SWR-1042D Subwoofer 10" 300W RMS 4 Ohm
• Peak Power 1500W
• RMS Power 500W
Kommentarer på:  alpine sub,,, priser
