2.029 visninger | Oprettet:
Søren N
Søren N
13. nov 2008
Følger: 1 Emner: 1 Svar: 2
Nystartet autohifi. Vurdering+råd? {{forumTopicSubject}}
Hey eksperter!
Jeg har lige måttet tage livet af mine drømme højttalere på hjemme-stereofronten, så nu er jeg ved at opgradere bil-anlægget, så jeg kan få noget kvalitetstid ude på vejene.. ; )
Jeg har indtil videre anskaffet mig følgende udstyr til bilen (intet er installeret endnu):
Headunit:
DXZ838RMP main features:
MP3 / CD / WMA receiver with RDS-EON radio. CD-R and CD-R/W compatible
ID-3 tag compatible
Shock-proof read ahead memory eliminates disc jumps
Motorised removable slim line front face with case included
Flashing anti-theft LED behind front panel
Variable display and button illumination colour (728 different shades)
Display dimmer, contrast adjustment and screensaver. Button illumination dimmer
Message system (your custom 30 char. message displayed for 30sec at turn on/off)
Infra red remote controller included
CeNET control system for optional CD changer and multimedia components
Beat-EQ sound control with three band parametric equaliser
High 4 x 53 Watt maximum power output
CD text display (if present on disc)
Listen to your mobile phone through radio speakers (via aux input)
Automatic muting when connected car phone is in use
Six channel preamp outputs (4.0 volt) for connecting external amplifier
Loop back circuit for optional Dolby Digital and DTS decoder
Two channel RCA auxiliary input for walkman etc.
Magna-Bass EX loudness enhancement
High sensitivity RDS/EON radio tuner with 24 preset stations (16 FM & 6 MW/LW)
Retractable rotary controller with non-slip design
Clock display option with auto-setting
Solid aluminium front panel flips down to insert CD
Supplied complete with full installation and operation guide
Front højttalere:
Boston Pro60SE
Competition 2-way car component system
6½" copolymer cone woofer with neodymium magnet 1½-inch voice coil
RadiaVent® cooling and Twinstage™ heat sink for increased power handling
Cast aluminum woofer basket
1" Type-M1 anodized alloy dome tweeter with full AMD™
Separable and dockable crossovers
VariMount™ adapter rings allow for fast installation
Axis-, flush-, and angle-mount tweeter mounting kit
Hattehylde: MDS fd 693(har desværre ikke lige specs)
Forstærker:
DHD NTX-2662
Channels 6 Wmax 1400W Bridged (4Ohm) 2x140Wrms+1x300Wrms,Stereo (4Ohm) 4x50Wrms + 2x100Wrms Stereo (2Ohm) 4x70Wrms + 2x150Wrms Frequency range 15-30,000Hz low-pass 30-250Hz, 24dB/oct. high-pass 50-1,000Hz, 18dB/oct. Dimensions 30 cm bredx5,5 cm tykx50 cm lang
Sub:Boxter pro eliminator 2x10" monteret i kabinet.
Vist nok 500watt
Efter den lange smøre af specs, er mit spørgsmål til I mange eksperter:
er min forstærker og sub for dårlig? skal jeg overhovedet montere hattehyldehøjttalerne(vil det ikke bare "rode" lydbilledet)?
Evt bare en generel vurdering og hvad den billigste(og bedste9 opgradering kunne være?(hælder mest til forstærkeren og sub´en..
jeg hører lidt af hvert, bla. rap men også pink floyd osv..
Jeg har desværre ikke meget mere end 2000kr til opgradering lige nu, så det kan godt være jeg skal spare mere op før jeg opgraderer..
Jeg er ikke bleg for at købe noget brugt, hvis jeg lytter og kigger på det først(det er min erfaring at man får MEGET mere for pengene)
Håber på nogle kompetente svar
Mvh Søren
Kommentarer på:  Nystartet autohifi. Vurdering+råd?
  • #1   14. nov 2008 Jeg ville ihvertfald skifte den forstærker og de subs ud hvis du gerne vil have noget rigtig godt lyd i bilen.
    Nu du har boston front sæt, så skal du da investere i en Boston G5 subwoofer dertil, og evt en god kvalitets 3 kanals forstærker...
    Drop dine hattehyldehøjtalere, de vil kun forvirre lydbilledet, og er der egentlig kun mest for passagerenes skyld.
  • #2   14. nov 2008 Den for stærker er SLET ikke optimalt til de to subs.
    Hver sub er på 4-ohm.......
    Og sætter du så 1 sub på hver sub-kanal, så kører de hver i 4-ohm, og yder derved ikke en skid.....
    Så hellere "nøjes" med at sætte en enkelt sub til, og så brokoble dem over kanal 5 og 6.
  • #3   14. nov 2008 Og som første opgradering, ville jeg HELT klart skifte den forstærker ud.
    Køb en mono-blok.... Til subs.
    Og en 2-kanals til dine fronter (evt en 4-kanals.)
    Og så drop de baghøjtalere.....
  • Søren N
    Søren N Tilmeldt:
    nov 2008
    #4   14. nov 2008 Super med så hurtige svar..
    Men allerede nu lugter det af at jeg skal skifte forstærkeren og sub´en, som jeg havde på fornemmelsen...
    Nåh ja, jeg må hellere nævne at det skal spille i en Peugeot 405 st.car, så det er vel egentlig en god idé med en større sub?( vel helst en eller to 12"ere..)?
    Og I snakker begge om gode kvalitetsforstærkere.. Hvad f.eks? uden jeg bliver ruineret helst.. ; )
  • Søren N
    Søren N Tilmeldt:
    nov 2008
    #5   15. nov 2008 Er der slet ikke flere som ligger inde med råd og vejledning vedr. sub og forstærker??
    Jan F: Har godt nok hørt/læst at der er mange som ikke ligefrem anbefaler MDS. Kender det ikke, så jeg kan ikke rigtig gøre andet end at høre på hvad andre synes.. Håber bare kritikken kommer fra nogen der rent faktisk har ejet noget MDS og ikke bare fra folk som råder ud fra rygter..
