1.253 visninger | Oprettet:
Hertz ml3000 mille {{forumTopicSubject}}
Hej nogle der har en idè til en forstærker til denne subwoofer?
Hertz Mille ML3000
Beskrivelse:
Svingspole: 1x4 ohm
Impedans: 4 ohm
Belastning: 750 watt RMS
Belastning: 1500 watt spidsbelasning
Montage dybde: 179mm
Ydre Diameter: 318mm
Monterings Diameter: 284
Specifikationer:
D : 253mm
Xmax: 19mm
Re: 2,6 ohm
Fs: 32hz
Le: 1,67 mH @ 1 khz
Le: 0,83 mH @ 10 khz
VAS: 39 lit
Mms: 197gr
Cms: 0,12 mm/N
BL: 14 T-m
Qts: 0,51
Qes: 0,53
Qms: 10,40
SPL: 89db
Ville det være dumt at bruge denne 4 kanals alphasonik og så brokoble den:
150 Watts x 4 @ 4 ohms Stereo
240 Watts x 4 @ 2 ohms Stereo
460 Watts x 2 @ 4 ohms Mono
Dimensions: (W x H x L) 8 1/4" x 2 5/8" x 22"
Hour Meter
Remote Mount Digital Voltmeter(included)
Heavy Duty One-piece Extruded Aluminum Heat Sink
Beveled Clear Acrylic Protective Cover
Tiffany-Style Input and Output RCA Jacks
Parallel Line-out RCA Jacks
MOSFET High Speed Switching Power Supply
Milspec Double-Sided Glass Epoxy Circuit Board with Through-hole Plating
Heavy 4 oz. Pure Copper PC Traces at All Preamp and Amplification Stages
Solid Brass Nickel-plated Terminal Blocks (4-gauge Power, 8-gauge Speaker)
THD: 0.05
Signal-to-Noise Ratio: >100dB
Frequency Response: 5Hz~50kHz
Input Impedance:10K ohms
Input Sensitivity: 200mV~8V
4-Way Protection Circuitry: Thermal, Short Circuit, Overload and DC Offset
Thermal Cooling Fan
Kommentarer på:  Hertz ml3000 mille
Hertz ml3000 mille
