Glædeligt nyt til Tiburon ejere 96-02 {{forumTopicSubject}}
Hey medlemmer
Så er der glædeligt nyt for dem af jer der ejer en Generation 1 Coupe/Tiburon. Altså fra produkt året 96-02
Har fået mig en god snak med sharkracing, samt med Hyundai's Korean office department
Sharkracing kan nu tilbyde "EURO license" stumper til skift af komplet nav på denne model. Dvs det er lovligt at gå fra 4 til 5 huls nav på denne model nu, forudsat stumperne er købt ved sharkracing altså da de stumper er testet i hoved og røv nu og blevet godkendt!
Altså kan det også synes i DK ;D
Så hvis i har nogen 5 huls fælge i har været forelsket i, men bare måtte opgive kan i nu få dem på, endda helt lovligt.
Jeg, som den første køber et sæt (Er allerede bestilt) og får det sendt til DK. Første registeret sæt de sender til DK
Smider jer lige den sidste email fra sharkracing så i får lidt mere info:
Hello,
I've been on vacation and it seems nobody here have seen your question or knew what to do with it, so i'm sorry for the late answer. But i'm sure you'll like what i'm about to tell you.
Now lets see, you need a PCD adapter. The wheel spacer that I was talking about is
only for 4 hole or 5 hole, but will not convert between the two.
The one you are talking about is possible to do, but a little dangerous,
so we don't sell anything like that. But it is fairly cheap to get access to here in the US and Korea, nothing like the price you are mentioning from Denmark and Germany. Just as good quality here, but for a far lower price you know. But it's just *TOO DANGEROUS* Believe me... Don't add something like that to your cars underbody, it's not safe Christian. We deliver parts to racing teams using the Hyundai Tiburon so i know what i'm talking about.
The safest way to do what you want is to change out the parts in your underbody that will allow you to convert to 5 hole. We can provide you with the parts to do this for only
US$750, including shipping.
This option will save you alot of money instead of buying that PCD adapter from Germany, which isnt safe at all.
This option is as safe as if it came from Hyndai all along, believe me we got loads of Tiburons over here driveing with our option and have NONE reported accidents with the use of these parts.
The spare parts would include hubs, bearings, knuckles, etc, basically everything needed to make the conversion safely. And with 100% FITTING. The price that we quoted is for ocean shipping.
Best regards
Håber i kan bruge det til noget måske
Mvh Chris
