2.230 visninger
blæser starter ikke? {{forumTopicSubject}}
hej jeg har det problem at min blæser starter ikke så jeg bliver nød til at skrue op for varmen hvis jeg holder stille i noget tid. Og det er jo ret træls hvad kan der være galt at den ikke gider starte? Har tjekket sikringer og de er alle intakte.
feb 2007
Følger: 121 Følgere: 130 Biler: 15 Emner: 79 Svar: 458
Følger: 63 Følgere: 70 Biler: 9 Emner: 531 Svar: 2.074
dec 2006
Følger: 200 Følgere: 198 Biler: 23 Emner: 257 Svar: 6.518
Og Bo, lyder mere som om din toppakning er blæst. Virker viskosen skal den ikke blive for varm.
dec 2006
Det skal bare være en fastnøgle uden knæk. Alle dem jeg har fundet når jeg har lavet viskosekobling har passet, så jeg kan ikke helt forstå hvorfor du ikke er lige så "heldig"
dec 2006
dec 2006
dec 2006
dec 2006
8 Disconnect the battery negative cable, and
rock the fan back and forth by hand to check
for excessive bearing play.
Caution: If the radio in your
vehicle is equipped with an antitheft
system, make sure you
have the correct activation code
before disconnecting the battery.
Note: If, after connecting the battery, the
wrong language appears on the instrument
panel display, refer to page 0-7 for the
language resetting procedure.
9 With the engine cold, turn the fan blades by
hand. The fan should turn with slight
resistance.
10 Visually inspect for substantial fluid
leakage from the fan clutch assembly. If
problems are noted, renew the fan clutch
assembly.
11 With the engine completely warmed up,
turn off the ignition switch and disconnect the
battery negative cable. Turn the fan by hand.
Heavier resistance should be evident. If the
fan turns easily, a new fan clutch may be
needed."
dec 2006
26 Disconnect the battery negative cable.
Remove the fan shroud mounting screws or
plastic fasteners, and detach the shroud (see
Section 4).
27 Use a 32 mm open-ended spanner to
remove the fan/clutch assembly. Place the
spanner on the large nut ahead of the pulley
(see illustrations), and tap the end of the
spanner to loosen the nut.
Caution: The nut has left-handed
threads, so it loosens by being
turned clockwise, as viewed from
the front of the vehicle.
28 Lift the fan/clutch assembly (and shroud,
if necessary) out of the engine compartment.
29 If necessary, remove the four bolts
attaching the pulley to the water pump hub.
The pulley can then be removed after
removing the drivebelt(s) (see illustration).
30 Carefully inspect the fan blades for
damage and defects. Renew it if necessary.
31 At this point, the fan may be unbolted
from the clutch, if necessary. If the fan clutch
is stored, position it with the radiator side
facing down.
32 Refitting is the reverse of removal."
dec 2006
