665 visninger
golf 3 {{forumTopicSubject}}
hej BG
jeg har i dag vært ude efter et andet speedometer til min golf 3 TDI
men i displayet står der INSP-2 og olie lampen blinker...
hvordan får jeg det væk??
håber der er nogle der kan hjælp.
tak på forhånd.
apr 2013
IN 00 = no service required
OEL = oil service
IN 01 = inspection 1
IN 02 = inspection 2
Now, since I cannot condone poor maintenence, I'll tell you how to get rid
of it as long as you're doing the maintenence. : )
1. Switch ignition ON.
2. Press and hold odometer reset button below speedometer.
3. Switch ignition OFF and release odometer reset button. OEL will now
display.
4. Press and hold the lower digital clock set button or the analog clock set
button until five dashes (-----) appear in display.
5. If necessary, pree odometer reset button to proceed to the IN 01 display
(15,000 mile maintenence) and reset using the clock button.
6. If necessary, repeat procedure to reset IN 02 (30,000 mile maintenence)
display.
7. To end reset mode: switch ignition ON; when display IN 01 appears, switch
ignition OFF.
golf 3
