3.041 visninger | Oprettet:  FølgFølg ikke 2 Svar
ESP og motorlampe lyser, Audi A3 1.6 FSI p8 ESP og motorlampe lyser, Audi A3 1.6 FSI p8
Hej
Har en audi A3 p8 1.6 FSI fra 03 som jeg har lidt bøvl med. Er der nogle der har en formodning om hvad det kan være galt. Jeg mistænker selv Egr-ventilen, og ABS pumpestyrenheden.
Testeren siger:
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 DS
Component: SIMOS71 1.6l 2V 9856
Revision: --H04--- Serial number: AUX7Z0C3FNE08A
Coding: 0000071
Shop #: WSC 46108 123 187143
VCID: 73EFD5D512C3C5A673-8026
4 Faults Found:
17923 - Intake Manifold Valve (N156)
P1515 - 007 - Short to Ground
Freeze Frame:
RPM: 736 /min
Absolute Pres.: 436.2 mbar
Temperature: 78.0°C
Load: 5.1 %
18080 - Coolant Fan Control 1
P1672 - 009 - Open or Short to Ground
Freeze Frame:
RPM: 576 /min
Temperature: 76.5°C
Temperature: 43.5°C
Speed: 1.0 km/h
17809 - EGR Valve (N18)
P1401 - 007 - Short to Ground
Freeze Frame:
RPM: 672 /min
Load: 0.0 %
Load: 20.0 %
Bin. Bits: 00000100
17833 - EVAP Purge Valve (N80)
P1425 - 007 - Short to Ground
Freeze Frame:
RPM: 704 /min
Temperature: 69.0°C
Load: 1.2 %
Voltage: 13.97 V
Readiness: 1110 1101
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0051846
Shop #: WSC 00045 204 06829
VCID: 336F15D5524385A6B3-8066
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H07 0040
Revision: 07 Serial number: 15000134011B58
Coding: 3D0F0342070100
Shop #: WSC 06435 000 00000
VCID: 2649FC819191E00E24-8072
2 Faults Found:
00469 - Infotainment Databus in Single Wire Operation
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 103
Mileage: 176105 km
Time Indication: 0
Date: 2015.11.04
Time: 21:21:48
01304 - Radio
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 176105 km
Time Indication: 0
Date: 2015.11.04
Time: 21:21:53
nogle andre gode bud.
RENAULT SCENIC E-TECH ELECTRIC - DIT VALG!
Slå lyden til
00:00
14:20
LIVE
NOW PLAYING
TOYOTA LANCERER SEKS NYE ELBILER!
NOW PLAYING
VW ID.4 GTX - OVERRASKER!
NOW PLAYING
TIL WAGRAIN OG HJEM I HALLES MINIBUS!
NOW PLAYING
MIN BMW E30 FÅR NY CHANCE
NOW PLAYING
NOW PLAYING
BYD TANG ER IKKE HELT FÆRDIGBAGT!
NOW PLAYING
NOW PLAYING
STATUS PÅ MIN BMW E30!
NOW PLAYING
NOW PLAYING
TOPFART I VW ID.3 GTX!
NOW PLAYING
ALFA ROMEO JUNIOR - NOGET ER GALT!
NOW PLAYING
BYD ATTO 2 - OVERRASKER STORT!
NOW PLAYING
NOW PLAYING
AT ANMELDE EN SPRITBILIST!
NOW PLAYING
NOW PLAYING
NOW PLAYING
MERCEDES-BENZ G 580 - 100% ELEKTRISK G-KLASSE!
NOW PLAYING
NOW PLAYING
NY TESLA MODEL Y
NOW PLAYING
NOW PLAYING
POLESTAR 4 MED 1900 KG PÅ KROGEN!
NOW PLAYING
I AUDI A5 AVANT TIL ST. ANTON!
NOW PLAYING
KAN MIN BMW E30 REDDES?
NOW PLAYING
NOW PLAYING
  • Sætte gardinskinner op i betonloft (Vidga ikea) 300 kr.
  • Tilstoppet toilet 1.000 kr.
  • Handyman to fit some blinds 1.000 kr.
  • Install shower mixer 500 kr.
  • Hænge gardiner op 500 kr.
  • Installere vaskemaskine 1.000 kr.
Kommentarer på:  ESP og motorlampe lyser, Audi A3 1.6 FSI p8
  • #2   12. apr 2016 Hvorfor tror du der ABS pumpeenhed er i stykker? den melder jo ikke fejl på trykføleren, men den refererer til at der er fejl i motorstyringen, og derfor er i fejl mode.
    Udover det, så har alle dine fejl teksten : short to ground. Direkte oversat hedder det kortsluttet til stel.
    Dog melder den også : short to ground hvis der mangler en plus. Og siden at de komponenter den melder fejl på har den fællesnævner at de bliver alle drevet af 12V ville jeg starte med at lede efter en sprunget sikring. Men der er nok en grund til at den springer.
  • #3   12. apr 2016 Kim P. Har du selv prøvet at slå fejlkoderne op i det skodlink?
    Jeg kan ikke finde dem, på de pladser hvor de burde være.
