801 visninger
Tester til Peugeot og Ford {{forumTopicSubject}}
Hej er lidt på udkig efter en tester den skal ihvertfald virke til en Ford Cmax fra 2013 med canbus
Og en Peugeot 206 fra 2001
Ville være dejligt hvis man kan kode om i forden tænker diverse funktioner
Ellers skal den bare læse og slette fejlkoder
Hvad kan i forslå ?
mar 2008
Følger: 2 Følgere: 1 Biler: 1 Emner: 11 Svar: 673
mar 2004
Følger: 2 Følgere: 78 Biler: 6 Emner: 385 Svar: 4.344
mar 2008
The ABRITES Vehicle Diagnostic Interface - AVDI is the latest generation diagnostics interface produced by Abrites ltd. for cars, bikes, trucks, water scooters, ATVs and water scooters.
Its main features are:
Compatible with all diagnostic software produced from our company
One year free updates of all applications from the basic diagnostic suite
One year free customer support by email
SAE J2534 compliant driver available for our interfaces
Compatible with many 3rd party diagnostic software
VCI emulator which can allow AVDI to emulate different interface units (like K-line interface, ELM327 interface, ..). Emulation allowing you usage of many additional 3- rd party software’s – Webasto TT, Evinrude Diagnostics, Suzuki/Yamaha Marine Diagnostics and many others.
Compatibility with VW/Audi/Seat/Skoda/Bentley/Lamborghini ODIS
Compatibility with Fiat EXAMINER
Supporting external communication link with transponder programmer and IC programmer
Compatibility with Toyota/Lexus/Scion Techstream
Compatibility with Honda/Acura HDS
Compatibility with Volvo VIDA
Compatibility with DAS/Xentry - Star Diagnosis
Compatibility with Nissan Consult III+
Compatibility with Ford Scanner
Compatibility with BMW - DIS over K-line and CAN bus
Compatibility with BMW - E-Sys, INPA, EDIABAS, NCS Expert, NFS over K-line and CAN bus
Compatibility with Rover/Jaguar IDS
Compatibility with Subaru Select Monitor III
Compatibility with Bombardier diagnostic software
Compatibility with GM - Tech2Win, GDS2 and SPS diagnostic software
Compatibility with HYUNDAI GDS
Compatibility with KIA GDS
The special functions developed by our company such as key programming abilities, security code extraction, etc. can be purchased separately. A full list of our special functions is available here: Specifications and prices
Currently AVDI is distributed with the following diagnostic software:
ABRITES Diagnostics for VAG - VW/Audi/Seat/Skoda
ABRITES Diagnostics for Porsche
ABRITES Diagnostics for Mercedes/Smart/Maybach
ABRITES Diagnostics for Opel/Vauxhall
ABRITES Diagnostics for Toyota/Lexus/Scion
ABRITES Diagnostics for Jaguar/Land Rover
ABRITES Diagnostics for BMW/Mini
ABRITES Diagnostics for Renault
ABRITES Diagnostics for Nissan
ABRITES Diagnostics for Peugeot/Citroen
ABRITES Diagnostics for Fiat/Alfa/Lancia
ABRITES Diagnostics for Ford/Mazda
ABRITES Diagnostics for Chrysler/Jeep/Dodge
ABRITES Diagnostics for DAF
ABRITES Diagnostics for Mitsubishi
ABRITES Diagnostics for Hyundai/Kia
ABRITES Diagnostics for Suzuki
ABRITES Diagnostics for Volvo
ABRITES Diagnostics for Daihatsu
ABRITES Diagnostics for Bikes/Snowmobiles/Water scooters
ABRITES Diagnostics for Subaru
J2534 PassThru driver that allows users to use 3rd party diagnostic software
Software for diagnostics for MAN and Scania is currently under development.
The interface will also be compatible with some of our other tools that are currently being developed like:
ABRITES Locksmith Tool
ABRITES Mileage Tool
ABRITES Tuning Tool
ABRITES SRS Tool
The Abrites Vehicle Diagnostics Interface (AVDI) is designed in conformity with the following European Directives: 2004/108 / EC, 2006/95 / EC, 2011/65 / EU, 2012/19 / EU and meets the following safety norms: EN61010-1: 2010, EN61326-1: 2013. It has been tested in the laboratories of TÜV Rheinland and has a GS certificate, which guarantees the high quality of the product. It evolves with every new car model to answer the increasing demands of the automotive business, which makes it the best choice for professionals and advanced enthusiasts.
Technical specification:
K-line ISO 9141 (100 mA) multiplexed to 24 different pins of the diagnostic connector
ISO14230 compliant
SAE J1850 VPW,PWM compliant (needed additional adapter)
Single wire CAN bus multiplexed to different pins of diagnostic connector
Dual wire low speed CAN bus multiplexed to different pins of diagnostic connector
Dual wire high speed CAN bus multiplexed to different pins of diagnostic connector
CAN bus GMLAN, ISO14229, ISO15765, J1939, ISO22901 compliant
Analog Input
Bluetooth connection (* optional)
USB interface to the PC
Supply voltage 8..30V DC
OBDII cable
Updatable firmware
mar 2008
Kan gå af med den for 5000.
mar 2004
