3.641 visninger | Oprettet:
Martin B
Martin B
30. aug 2015
Følger: 1 Emner: 7 Svar: 24
Golf 6 1,6 TDI HJÆLP VISER MANGE FEJL PÅ VCDS {{forumTopicSubject}}
Hej er der nogle der kan forklare mig hvad der er galt med min bil? Lige umiddelbart synes jeg ikke den fejler noget når jeg kører i den. Men jeg målte følende på den da jeg satte VCDS tester på den.
01-Engine -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 MN HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 8892
Revision: --H43--- Serial number: 00000000000000
Coding: 08114016032401080000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM16TDI02103L906023MN 003004
ROD: EV_ECM16TDI02103L906023MM.rod
VCID: 7EF31873E102AEEEE6F-802B
2 Faults Found:
9867 - Coolant Pump 2
P261A 00 [032] - Open circuit
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 168488 km
Date: 2062.14.31
Time: 09:17:19
9870 - Coolant pump 2
P261B 00 [096] - Implausible signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 168493 km
Date: 2062.14.31
Time: 09:22:15
Readiness: 1000 0000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 113B200D092A0003880E04E8901A0051310000
VCID: 76E30053C132E6AEBEF-8023
4 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 174
Mileage: 167038 km
Time Indication: 0
Date: 2062.14.12
Time: 20:22:27
Freeze Frame:
Count: 1
Count: 2
Count: 20992
Count: 8194
Count: 44288
Count: 0
Count: 253
Count: 0
01169 - Door Contact Switch Driver Side (F2)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 174
Mileage: 167035 km
Time Indication: 0
Date: 2062.14.12
Time: 20:11:19
Freeze Frame:
Count: 15
Count: 2
Count: 20992
Count: 147
Count: 51457
Count: 0
Count: 253
Count: 0
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 174
Mileage: 167034 km
Time Indication: 0
Date: 2062.14.12
Time: 20:10:15
Freeze Frame:
Count: 8
Count: 2
Count: 20992
Count: 83
Count: 51457
Count: 0
Count: 253
Count: 0
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 174
Mileage: 167034 km
Time Indication: 0
Date: 2062.14.12
Time: 20:10:15
Freeze Frame:
Count: 8
Count: 2
Count: 20992
Count: 67
Count: 51457
Count: 0
Count: 253
Count: 0
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 EA HW: 5K0 907 044 EA
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0000000003
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 6ED32833B162DE6E76F-803B
2 Faults Found:
13701376 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 174
Mileage: 167038 km
Date: 2062.14.12
Time: 20:22:28
9481200 - Coolant Pressure
B10AB F0 [008] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 186
Mileage: 167385 km
Date: 2062.14.17
Time: 09:58:54
Address 09: Cent. Elect. Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 084 D HW: 1K0 937 084 D
Component: BCM PQ35 B 103 BFM PQ35% B 106 03150615
Coding: 40180A3A80251AC040080080540000E443610080624D8560648087200041
Shop #: WSC 12345 123 12345
VCID: 2F6DF5377EE897663D9-807A
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 23031 23 0012
Coding: 009795
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RA3766/
Coding: 00003947
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360_VW01.rod
VCID: 3169F34F60DC81962BD-8064
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME792E555EZZZB
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME637A505CZZZ%
Crash sensor for side airbag; rear driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME5A2F084BZZZ3
Crash sensor for side airbag; rear passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME76181D7AZZZ2
No fault code found.
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BA HW: 5K0 953 549 C
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KCO000TR
Coding: 5080140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS.rod
VCID: 70EF364BAB56C89E643-8025
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K0 920 871 A HW: 5K0 920 871 A
Component: KOMBI H20 0420
Coding: 170D00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 2C57E23B47FEEC7E18B-8079
1 Fault Found:
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 174
Mileage: 167038 km
Date: 2062.14.12
Time: 20:22:27
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H35 0614
Revision: H35 Serial number: 290311F1003158
Coding: 350002
VCID: 3169F34F68DC81962BD-8064
1 Fault Found:
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 174
Mileage: 167038 km
Time Indication: 0
Date: 2062.14.12
Time: 20:22:28
Address 25: Immobilizer Labels: None
Serial number: 00000050000005
Coding: 0500004F2020
ASAM Dataset: EV_Immj_UDS_VAD_RM09 A03008
ROD: N/A
VCID: 55A167DF34F48DB6975-8000
No ASAM data for: "EV_Immj_UDS_VAD_RM09" (VW36)
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2119
Coding: 0131252
VCID: 3169F34FA8DC81962BD-8064
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
VCID: 3467FA5B57CEB4BE40B-8061
2 Faults Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 3
Reset counter: 174
Mileage: 167042 km
Time Indication: 0
Date: 2062.14.12
Time: 20:36:32
Freeze Frame:
Voltage: 14.25 V
DU
Temperature: 40.08C
RPM: 1792 /min
Speed: 16.0 km/h
Speed: 16.0 km/h
Count: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 174
Mileage: 167042 km
Time Indication: 0
Date: 2062.14.12
Time: 20:31:54
Freeze Frame:
Voltage: 12.50 V
DU
Temperature: 40.08C
RPM: 1498 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0131252
VCID: 326BFC43ADDABA8E527-8067
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2L9183220
Coding: 0500040004
VCID: 65C1571F6C941D36075-8030
4 Faults Found:
00874 - Treble Speaker Front Left (R20)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 120
Mileage: 166327 km
Time Indication: 0
Date: 2062.14.06
Time: 17:15:25
00875 - Treble Speaker Front Right (R22)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 120
Mileage: 166327 km
Time Indication: 0
Date: 2062.14.06
Time: 17:15:25
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 120
Mileage: 166327 km
Time Indication: 0
Date: 2062.14.06
Time: 17:15:25
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 120
Mileage: 166327 km
Time Indication: 0
Date: 2062.14.06
Time: 17:15:25
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H35 0614
Coding: 030B185A
VCID: F1E9B34F285C4196EBD-80A4
Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
Component: J367-BDM H07 0150
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0131216
Shop #: WSC 01357 011 1012552
VCID: 3561C75F5CB4ADB6775-8060
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0131216
VCID: 3663C05341B2A6AE7EF-8063
End ---------------------------------------------------------------------
Kommentarer på:  Golf 6 1,6 TDI HJÆLP VISER MANGE FEJL PÅ VCDS
