Kommentarer på:  fejlkode P0101 på en sprinter
  • #1   25. jan 2012 OBD Code P0101refers to
    Basically this means that there is a problem with the Mass Air Flow (MAF) sensor or circuit. The PCM detects that the actual MAF sensor frequency signal is not within a predetermined range of the calculated MAF value for more than 4.0 seconds
  • #2   25. jan 2012 hvad plejer det at være galt så smiley
  • #3   25. jan 2012 luftmassemåler
  • #4   25. jan 2012 den har fået en ny.
    andre muligheder ???
  • #5   26. jan 2012 What does this mean?
    Basically this means that there is a problem with the Mass Air Flow (MAF) sensor or circuit. The PCM detects that the actual MAF sensor frequency signal is not within a predetermined range of the calculated MAF value for more than 4.0 seconds.
    Symptoms
    Possible sumptoms of OBD code P0101
    You will likely not notice any serious drivability problems, although there may be symptoms.
    Possible Solutions
    The simplest thing to do is to reset the code and see if it comes back. Then start with the cheapest, easiest repair procedures: Inspect for the following conditions: An incorrectly routed harness--Inspect the harness of the MAF sensor in order to verify that it is not routed too close to the following components: - The secondary ignition wires or coils - Any solenoids - Any relays - Any motors A low minimum air rate through the sensor bore may cause this DTC to set at idle or during deceleration. Inspect for any vacuum leaks downstream of the MAF sensor. A wide open throttle (WOT) acceleration from a stop should cause the MAF sensor g/s display on the scan tool to increase rapidly. This increase should be from 6-12 g/s at idle to 230 g/s or more at the time of the 1-2 shift. If the increase is not observed, inspect for a restriction in the induction system or the exhaust system. The barometric pressure (BARO) that is used in order to calculate the predicted MAF value is initially based on the MAP sensor at key ON. When the engine is running the MAP sensor value is continually updated near WOT. A skewed MAP sensor will cause the calculated MAF value to be inaccurate. The value shown for the MAP sensor display varies with the altitude. With the ignition ON and the engine OFF, 103 kPa is the approximate value near sea level. This value will decrease by approximately 3 kPa for every 305 meters (1,000 feet) of altitude. A high resistance on the ground circuit of the MAP sensor can cause this DTC to set. Any loss of vacuum to the MAP sensor can cause this DTC to set. If you suspect the condition may be related to aftermarket accessories, refer to Checking Aftermarket Accessories in Wiring Systems.
  • henrik s
    henrik s Tilmeldt:
    okt 2004
    Følger: 2 Følgere: 1 Svar: 1
    #6   18. okt 2018 Fandt du ud af hvad der var galt...?
