Kommentarer på:  honda motor...
  • #1   2. feb 2012 D16A8
    Found in:
    1988–1995 Civic/CRX/Concerto (UK/Europe/Australia)
    1992–1995 Rover 216/416 GTi (UK/Europe)
    1993–1997 Rover 216 Sport Coupé (Europe)
    Displacement : 1,590 cc (97 cu in)
    Bore and Stroke : 75 × 90 mm (3.0 × 3.5 in)
    Compression : 9.5:1
    Power : 122 PS (90 kW; 120 hp) at 6,800 rpm
    Torque : 14.9 kg·m (146 N·m; 108 lb·ft) at 5,900 rpm
    Valvetrain : DOHC (4 valves per cylinder)
    Fuel Control : OBD-0 and OBD-1 MPFI
    ECU Code : PP5 (OBD-0), P29 (OBD-1)
    Head Code : PM7
    Gearbox : L3
    D16Z5
    (Basically the same engine as the D16A9, but now with a catalytic converter and lambda sensor)
    Found in:
    1988–1992 Honda CRX (European Market)
    Compression : 9.5:1
    Power : 124 PS (91 kW; 122 hp) at 6,800 rpm
    Torque : 14.3 kg·m (140 N·m; 103 lb·ft) at 5,600 rpm
    Valvetrain : DOHC, four valves per cylinder
    Cam Gear : 34 tooth
    Fuel Control : OBD-0 PGM-FI
    Head Code : P7
    Piston Code : PM7
    ECU Code: PM7
  • #2   2. feb 2012 takker, har den ene motor i bilen og den anden stående ved siden af... men der har været cat på den D16a8 motor jeg har fra min donor bil...
  • #3   8. feb 2012 mener du ikke d16a9 ?
  • #4   11. feb 2012 nope....
honda motor...
