1.845 visninger | Oprettet:
hvad betyder v-.spec på skyline? {{forumTopicSubject}}
hei bilgalleri,
var til DHB, hvor vi stødte ind i en skyline v-spec. Fik at vide af en kammerat at det betyder, at der ligger en V6 i istedet for en R6.
Mener selv at det er forkert og at det stadig er en R6 der ligger i og at det bare er noget med en anden diffrenciale og andre bremser.
Har prøvet at finde det her inde under, men fandt ikke et brugbart svar.
Ved der er nogen kloge hoveder der ved lidt mere om det end vi gør. Vi ved nemlig intet.
På forhånd tak.
Kommentarer på:  hvad betyder v-.spec på skyline?
  • #1   10. jun 2012 I hvert fald intet med V6 og række 6 at gøre. V6'er kommer først i R35'eren. Det er specielt udstyr og bremser/undervogn som du selv er inde på.
  • #2   10. jun 2012 R32
    To celebrate the success of the GT-R in both Group N and Group A racing, Nissan introduced the Skyline GT-R V-Spec ("Victory SPECification") car on February 3, 1993. The V-Spec added Brembo brakes and a retuned ATTESA E-TS system to the Nismo and N1 packages, as well as 17" BBS wheels with 225/45/17 tires. The V-Spec has a list price of ¥5,260,000.
    Finally on February 14, 1994 the Skyline GT-R V-Spec II was released, with the only change being wider 245/45/17 tires. In addition, both the V-Spec and V-Spec II had a curb weight of 1,480 kg (3,256 lbs), weighing 50 kg (110 lbs) more than the standard GT-R.[12] Total production of the V-Spec I and II was 1,453 and 1,303 units respectively.
    Total production of the R32 Skyline GT-R was 43,394 units, with production starting on May 22, 1989. An above average proportion of the GT-R's were sold in white: this is likely because white is the national racing color of Japan in international motorsport.
    R33
    The R33 GT-R launched in January 1995 with the base model GT-R and the V-spec model. The V-spec model weighed in 10 kg (22 lb) heavier, and had sportier suspension resulting in lower ground clearance. The V-spec also featured the newer ATTESA E-TS Pro all wheel drive system, which included an Active Limited Slip differential. The V-spec model also included a four wheel independent channel anti-lock braking system.
    Alt sammen fundet på Google.
