836 visninger
Opel zafira a {{forumTopicSubject}}
Hej allesammen.. Er der nogen der ved hvor modstanden sidder til blæseren på en Opel zafira a OPc årg2002 ... Kan ikke finde lortet bag handskerummet :-)
okt 2003
Følger: 1 Biler: 4 Emner: 13 Svar: 1.610
Fra Google.
I found the resistor, thanks to the Haynes manual I checked at the local library. No need to remove any blower motor, just remove the pollen filter and you can easily push it out from inside the air duct. Haynes describes the operation in 4 simple steps:
1. Remove glovebox
2. Remove lower trim panel and the air duct
3. Unclip the cover and remove the pollen filter
4. Push the resistor upwards disconnect the wires and 'voila'
Opel zafira a
