Subaru Impreza 850hk Subaru Impreza 850hk
http://www.vimeo.com/1975245
Gobstopper Specs:
Power = 850 bhp
Weight = 1120 kgs
Intended use: street/track/hill climbs/drag strip/time attack
Body
WRC steel arches WRC front and rear bumpers
WRC carbon rear spoiler
FIA T45 multi point welded in roll cage
STi alloy bonnet with RCMS heat extraction vents and gas struts
Heated front screen
WRC non heated lightweight rear screen
Engine
2.0Litre closed deck subaru block
RCMS extreme arrow rods
RCMS 75mm steel crankshaft
RCMS omega flat top pistons (coated) compression ratio 9.5:1
V4 STi cylinder heads with WRC/RCMS O-ring head gaskets and gas rings
One piece Nimonic exhaust valves
One piece stainless inlet valves
RCMS uprated valve springs
Plasma nitrided titanium spring caps
WRC main and big end bearings
WRC R-Profile high wrap cam belt system
RCMS modified oil pump to suit R-Profile belt
WRC S10 inlet manifold
RCMS eight injector kit
RCMS 72mm throttle body
RCMS 5.5 litre alloy sump
WRC short runner exhaust manifold
Garret GT 35-40 turbo with speed sensor
K&N air filter with RCMS 100mm inlet trumpet
RCMS high flow intercooler with twin tube core
70mm stainless steel intercooler pipe work
Electronics
M800 Motec ECU with traction control,nitrous control,anti-lag
paddle shift control,and full engine management control and data login
Motec dash with data login
Defi gauges for turbo,oil,fuel pressure
Interior
FIA carbon kevlar Recaro seats
FIA Sabelt 6-point harness
Transmission
R180 STi rear axle 3.9:1 cwp and plated Modena LSD differential
GKN rally drive shafts front and rear
Torque line carbon fibre propshaft
Six speed subaru gearbox casing modified for sequential housing
Six speed Modena gear kit
Subaru 3.9:1 front cwp
RCMS sequential system
RCMS paddle shift system
Plated centre diff with 1:1 uprated output Modena gears
Plated front Modena differential
Fuel System
FIA spec 26 litre rubber/kevlar bag tank in aluminium cover
Twin Bosch fuel pumps (200 litre per pump)
-8 Goodrich fuel feed pipe
-6 Goodrich fuel return pipe
-6 fuel cooler with cooling fan on return
RCMS 8 injector distribution block
2x SX fuel regulators running at 4 bar static pressure
Suspension
WRC spec EXE-TC fully adjustable dampers
High and low speed bump + rebound adjustment
STi Rose jointed rear lateral links
STi Rose jointed rear trailing links
EXE-TC bottom rose jointed upright bushes
STi alloy front arms (polished)
STi quick-steer steering rack
Other
WRC roller bearing single piece steering column
Momo suede steering wheel
Nitrous
NX full wet system
121bs carbon bottle with heater jacket
High flow shark nozzle
Motec auto control or driver manual system
Adjustable from +35bhp to +400bhp
Clutch
RCMS spec triple plate alloy cover OS Giken clutch and flywheel
RCMS hydraulic light pressure system
Quick release dry brake fluid connection
Brakes
AP 355mm six pot front (track and road use)
AP 304mm four pot front (drag strip use)
AP 290mm four pot rear with floating discs
RCMS hydraulic carbon handbrake
-3 stainless steel goodrich pipe work and fittings
Wheels
Road/Track use 19x8 forged alloy 1 piece rims
Drag strip use 15x8 spun alloy 3 piece rims
If you have any queries about parts or anything else regarding the car, ring Olly or Simon on 01455 828610 or look on the website www.rogerclarkmotorsport.co.uk
nov 2003
Følger: 43 Følgere: 42 Biler: 4 Emner: 65 Svar: 1.592
http://www.vimeo.com/2706234
dec 2006
Følger: 37 Følgere: 36 Biler: 3 Emner: 40 Svar: 959
maj 2005
Følger: 22 Følgere: 22 Biler: 2 Emner: 211 Svar: 977
feb 2006
Følger: 41 Følgere: 50 Biler: 1 Emner: 8 Svar: 126
BADEHJERNE!!!!
feb 2006
feb 2006
mar 2006
Følger: 78 Følgere: 71 Biler: 3 Emner: 26 Svar: 262
feb 2006
Jeg er HELT indebrændt over dig...
jun 2003
Følger: 27 Følgere: 24 Biler: 10 Emner: 126 Svar: 208
nov 2003
Jeg hopper bare tilbage til der hvor jeg kom fra
www.hestegalleri.dk + http://bp1.blogger.com/_t3LvP47oDlY/SIafY66WdQI/AAAAAAAABBo/psD4MumUuV8/s400/0626viagra.jpg
Hvem vil med?
x)
jul 2004
Følger: 58 Følgere: 85 Emner: 75 Svar: 3.210
nov 2003
Men kunne være den fik røv i år.... Norris Designs har fået ny gearkasse GT42 lader osv 900hk+ så man kan kun håbe der bliver lidt konkurrence i toppen af toppen
jul 2004
