1.357 visninger
Strøm kabel størrelse, {{forumTopicSubject}}
Hej,
Jeg er lidt i tvivl hvor stort et strøm kabel og stel kabel, jeg skal smide i min bil.
Det skal trække,
2 forstærkere, hattehylde højtalere, og 2 10" subs.
Alt sammen Alpine.
på forhånd tak.
okt 2008
Følger: 33 Følgere: 32 Biler: 2 Emner: 8 Svar: 143
Hvad mange rms watt er de på, og AMP
aug 2004
Følger: 22 Følgere: 26 Biler: 3 Emner: 42 Svar: 1.621
jul 2009
Følger: 60 Følgere: 59 Biler: 1 Emner: 44 Svar: 184
feb 2008
Følger: 14 Følgere: 12 Biler: 2 Emner: 9 Svar: 713
Men se guiden herinde.
http://www.altombilstereo.dk/modules/FAQ/index.php?op=viewcategory&cid=1#1
Burte være lige til at finde ud af.
dec 2009
Følger: 18 Følgere: 17 Emner: 6 Svar: 14
dec 2009
•400 watts RMS x 1 at 4 ohms (600 watts RMS x 1 at 2 ohms)
•variable low-pass filter (50-200 Hz, 24 dB/octave)
•tuned Bass EQ (0-12 dB bass boost at 50 Hz)
•subsonic filter (24 dB at 15 Hz)
•MOSFET power supply
•CEA-2006 compliant
•STAR Topology (minimizes internal noise and prevents ground interference)
•speaker- and preamp-level inputs
•gold-plated screw terminals
•fuse rating: 30A x 2
•8-gauge amp wiring kit with 60-amp fuse recommended — wiring and hardware not included with amplifier
•12-13/16"W x 2-3/8"H x 9-9/16"D
•4-channel car amplifier
•40 watts RMS x 4 at 4 ohms (50 watts RMS x 4 at 2 ohms)
•100 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
•2-, 3-, or 4-channel output
•variable high-pass/low-pass filters (50-400 Hz, 12 dB/octave)
•tuned Bass EQ (12 dB bass boost at 50 Hz for channels 3 & 4)
•subsonic filter (15 Hz, channels 3 & 4 only)
•CEA-2006 compliant
•preamp outputs
•fuse rating: 15A x 2
•8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
•11-1/4"W x 2-3/8"H x 9-9/16"D
jul 2009
jul 2009
dec 2009
Men betyder det så jeg skal lægge det samen, altså 60 amp for ene, og 30 for den anden = 90, og gå ud fra det på skalaen, på overstående link.
