PCV ventil PCV ventil
Hej er der en som er hurtig til at læse eng for jeg har noget om sådan en ventil men kan ikke forstå hvad det lige er de mener. der skulle vel ikke være en som ville læse det også genfortalle det på dansk? det er små 10 linier.
hilsen rasmus.
jul 2004
Følger: 58 Følgere: 85 Emner: 75 Svar: 3.210
maj 2005
Følger: 57 Følgere: 58 Biler: 5 Emner: 104 Svar: 1.059
feb 2006
Følger: 50 Følgere: 48 Biler: 2 Emner: 117 Svar: 1.812
mar 2006
Følger: 48 Følgere: 45 Biler: 3 Emner: 94 Svar: 1.099
mar 2006
feb 2006
At the part throttlr, the blow-by gas in the crankcase flows into the intake manifold through the connecting hose of crankcase and PCV valve by the strong vacuum of the intake manifold. under this condition, yhe fresh air is introduced into the crankcase through connecting hose of rocker cover.
at wide open throttle, a part of blow-by gas flows into the air intake duct through the connecting hose and is drawn to the throttlr chamber, ecause under this is condition, the indtake manifold vacuum is not so strong as to introduce all blow-by gases increasing with engine speed directly through the PCV valve.
det skulle være det...
feb 2006
mar 2006
feb 2006
mar 2006
feb 2006
PCV ventil
